was looking at replacing my current cca cadence with some welding cable...are they any disadvantages to this? Or should i just stick with car audio cable even if its about double the price per foot?
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
welding cable is very good, it will def do better then the wire your using now..there isn't really much of a difference, welding cable will handle more heat. more people will chime in, im running running welding cable from alt + to batter +
i had 3 runs of cca power and 3 runs of cca ground (from the front to back )
voltage was fine
OFC will handle more heat/power per foot
but unless your going to be in the lanes trying to sqweez every tenth of a DB out of your system id say just add another run of CCA
i always found it funny how everyone hates on CCA but AQ and other brands use ALUMINUM voice coils....
if you still plan on running 3500+ rms either pull it all out and go OFC
or add another run or two of CCA for good measure
down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups
^^ Cant wait to swalllow Ghost's babies
I've run 3/0 flex a prene welding cable and was more flexible than alot of good audio wire i've seen. Its not comparable to KNU or kicker wire but it does a good job
Everythings in the attic or garage since the truck was sold last year. New build should be coming soon in a dodge cummins smile.gif
weldingsupply.com has some good cheap prices on wire up to 4/0 if you got the welding cable route
2002 Honda CR-V
Alpine 9887
My Build
Rebuilding...
Second Skin Damp
4 DC XL 15's
2 DC 5ks
Singer 320 amp
6 cap banks
Sky High wire
2 VM-1's
OM-1
all under window line
Team DC Audio
Obama has a law he's trying to pass right now, trying to ban Leo for being a threat to children everywhere.
EDIT: Not in a JP kind of way.
I thought I was going to die from all the jizz filling my ears.
voltage was fine
I think people hate on cca because a lot of newbs don't realize there's a difference so they just go for the cheaper wire, then they end up with wire that's not really sufficient for their system. Also, not everyone wants to try to fit multiple runs of wire through their car.
truth but i have OCD and for every batt i need a run of 1/0 lol
it is a bitch to cut/find places to run alot of wire that isnt as flexible as most OFC
but oh well ive seen it work for ground pounder's AND number chaser's
just gotta do your research
I have over 400' of 2/0 welding cable in my truck and it works great. www.weldingsupply.com has the bet prices I have found. The 2/0 welding cable is about the same size and the Knu OFC 1/0 also.
Left to right.
Knu 1/0 OFC, Knu 1/0 CCA, 2/0 Welding Cable, 1/0 welding cable.
I doooo plan on running 3500 + watts and that's why I'm trying to prepare myself for it. And in my car, the less cable the better because i really have no way of running 1/0 gauge through my car without hacking away at some of the body. Soooo i should look into 2/0 gauge welding cable instead of 1/0 gauge?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
voltage was fine
I currently have CCA and it works fine for what I need it for, but I plan on upgrading and I figured the better quality wire would....well, better suit my needs
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
  • Who's Online   0 Members, 0 Anonymous, 3490 Guests (See full list)
